Question 1.8 mixture help
well the motor is fully reassebled ( except exhaust ) now that it is cranking but not starting i need to know how many turns the mixture and idle screws should be turned out, i had played with them before i pulled the motor trying to get it to run right
i smell gas and i have spark so that is not the problem and the timing is close enough to start as well
so anybody have any ideas
TIA
scott thacher
75 1.8 under construction
75 under rust
(fine german rust)
Old 03-16-2001, 07:37 PM
