help -- 914 wheels
I need wheels for my car. 15- 7 or 8. Does anyone know any companies that make them?? I have 11.75 rotors on the front with dynalite calipers... I can fid the 2000$ sets but I would rather not spend a fortune.. thanks phil. email scca_stmod@yahoo.com
Old 03-17-2006, 04:54 PM
Jim Smolka's Avatar
Need to know if you car is flared. If it is not flared, then 16x6 is a good option. Since it appears you have a V8, wider tires may be needed.
Also, is the car 5 or 4 lug.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 03-17-2006, 05:52 PM
Want to be's Avatar
I do not think anybody makes new fake fuchs forsale in 15 x 7 or 8's "if anyone know... please advise me"
There is a gentleman on ebay who sell 16 7 and 8 for around $569.00
They look really nice... if you need the link i have it saved on my pc...
jpc
Farmers Automotive 1-800-213-6373
http://www.farmersautomotive.com
1987 928S4,1989 911 25th, 1993 RSA, 1989 944,1988 911 1968 912, 1976 911 S, 1975 914
Engine dyno
http://www.youtube.com/watch?v=tJKdvrX_mTI&feature=youtube_gdata_player
Old 03-18-2006, 07:46 PM
jhadler's Avatar
You can get some pretty decent 15" light weight wheels from spin werkes. They were the supplier for circle racing.
I've been looking at a set of 15x8's from them. 11 lbs each, at $238 each. Custom built, any backspace, any bolt pattern.
-Josh2
Old 03-20-2006, 02:37 PM
mike mueller's Avatar
I had 12" rotors on mine (4 lug car) luckly I have Revolution 17" rims, wouldn't fit with the 15" Fuchs (a 16" rim would work I think, the caliper to rim interferance wasn't too bad on the 15" rim)
'73 914, 1.7, with Boxster transmission in the future?
Old 03-28-2006, 06:09 PM
stock rotors
I have 195 50 15 tires on empi rims. The problem is that low profile results in a car that is revving quite high at fwy speeds resulting in lousy gas mileage.
I woul d like some opinions. If I went to a 60 or 65 series tire woiuld that bring my revs down without adversly affecting the cornering?
If I jumped to 16s, which would make all of this much more expensive, what profile would make the speedo accurate?
"zumwoll" German for "to well being"---what happens when you drive a Porsche!
Old 03-29-2006, 07:18 PM
914 Geek
There would be an adverse effect on cornering by going to a taller sidewall. The ride will get softer, the car less responsive. (By no means will it get "soft" or "unresponsive", though! It's still a 914 after all!!) Most people feel that the compromise in cornering is worth the trade-offs... And the original tires were significantly taller than 195/50s anyway!
OEM is 165/80-15, so the nominal sidewall height is 165mm * 0.8 = 132mm = 5.2". There's a sidewall on each side of the rim, so that's 10.4", added to 15" gives you 25.4".
If you want to use 16s, you need 11.4" of total sidewall, or 5.7" on each side of the tire. That's ~145mm, which on a 195 means about a 0.75 "aspect ratio". So you'd still be running a fairly tall tire to get the stock rolling diameter to keep the speedo relatively accurate.
Crunch the numbers yourself. There are lots of alternatives...
--DD
Old 03-29-2006, 08:07 PM
Send a message via AIM to Jake Seidel Send a message via Yahoo to Jake Seidel
I have Empis with stock tires and there is very little room on the outside. If I went to 195 60 15 would they fit under the stock fenders. I can fit like two finger in it between the tire and the fender .Is the lack of room on my car unusual?
Jake seidel
72 1.7 914
90 Honda Accord
91 Honda Accord
95 BMW 540i FS
Old 03-30-2006, 05:12 PM
914 Geek
Sounds like you may have Empis with a Bug offset. Chances are pretty good that you can't fit much more than a 165 if that is case.
Check how much room you have. The width number is in millimeters (theoretically), half of which would be on the inboard side and half on the outboard side. 195s would be 30mm wider than 165s (in theory!) so if you have about 20mm between the sidewall and the fender (30/2 = 15 +5 for safety) you ought to be able to fit at least some 195s. (In which case, you have 914-offset Empis!)
Remember that 914s encounter tire fitment problems in the rear, not in the front.
--DD
Old 03-31-2006, 10:25 AM
RETIRED
Joe Bob's Avatar
is this guy coming back....?
Need more information for a better answer.....
2012 ML350 3.0 Turbo Diesel
Old 04-01-2006, 09:01 PM
