I have a 72 914 1.7 and am missing my fuse box cover inside the car and could use a nice layout of the fuses needed from left to right. My car also is idling at about 2500 what should I dop to fix this? I have tuned the points is there anything else causing this.
Thanks Jake
Jake seidel 72 1.7 914 90 Honda Accord 91 Honda Accord 95 BMW 540i FS |
Banned
914 Geek
The fuse information is also available in the "914 tech specs" section of this very website.
High idle is usually caused by one of two things: Vacuum leaks, or advanced timing. Verify the timing, and then start hunting for vacuum leaks. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Control Group
The lid is the same as for a late model Super Beetle, like $7, or you could get the one with pictures instead of numbers 1-12 for about $40
She was the kindest person I ever met |
