adding a 911 oil temp gauge
is there a definitive answer to what i need to get...
exactly what sender do i need to add a 1969 911 oil temp gauge in place of my parking brake light. where can i get it?
also, what adapter issues will i run into? where can i get it?
i also have a pressure gauge i wouldn't mind adding somewhere. same questions as above.
thanks tons!
paul
Old 05-12-2006, 12:19 PM
bfrenz's Avatar
Paul,
Whats this for 911 engine or a 914 engine.
1973 914-6 3.2 Motronic
Old 05-12-2006, 12:37 PM
RETIRED
Joe Bob's Avatar
To run an oil PRESSURE gauge you will need the VDO dual circuit sender that runs the pressure and idjut lght. The temp sender is a seperate unit.
2012 ML350 3.0 Turbo Diesel
Old 05-12-2006, 12:49 PM
Ok, here's my 2 cents worth.
If your car has never had an oil temg gauge before, you will need to acquire a "taco plate". On the bottom of a type 4 engine, there is a 3" round plate that is off to the side. This gets replaced with the "taco plate" and has a mounting point for a temp sender.
If you have a '72 & later car, the wiring should already exist and there will be a wire near the battery that is currently not being used (I believe the wire is green). This attaches to a short wire that goes to the sender.
Then, near the shifter, under the carpet will be a group of unused wires that are for the temp gauge, clock, and volt gauge that would normally be mounted in the optional center consol.
It sounds like you are not planning on going the console route and want to mount the temp light in an existing dash gauge. This is not my area of expertise but in case you are not aware, there is an optional gauge for the 914 that's called a combo gauge and is exactly the same as the left gauge with the brake warning light. The "combo gauge" has an additional oil temp gauge at the top.
Hope this helps........................Vern
Old 05-12-2006, 01:49 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
taco plate:
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 05-12-2006, 02:37 PM
