Thanks Dave thats just what I want to know.(bloody ripper)
Old 05-15-2006, 04:46 PM
hardflex's Avatar
A good thread for reviving....
for clarification, when you're measuring the rear toe with a string, each side will be 1/8" toe in from the string , not a 1/16" each side, total toe of 1/8. At least that's what you're shooting for, right?
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 10-07-2006, 12:46 PM
If you are shooting for 1/8" total toe in on the rear, you must have only 1/16" toe in on each side....totalling 1/8" toe in.
Old 10-07-2006, 05:00 PM
Read the Smart Strings and Smart Caster manuals.
http://www.smartracingproducts.com/installation.htm
You can use tubing attached to the bumpers to connect the strings to.
Make sure the car is level!!
Ken
Anything worth doing is worth doing in excess
Every silver lining has a cloud
Assume Nothing
Old 10-07-2006, 09:43 PM
sww914's Avatar
I've been so lucky, I've done alignments on about 20 different 914's and I've never broken a bolt. I've always used an impact to loosen them at first, maybe that's the holy grail.
I'm sure that you don't need to remove all 3 bolts to add or remove shims, only 1. The shims are slotted for 2 of the bolts, only the one in the corner needs to be removed.
Old 10-08-2006, 10:59 PM
