Carb linkage. different setups
I've noticed some carb linkage setups have the linkage towards the back and then some have it towards the front, with the accel. cable coming from between the firewall and engine.
Is it a matter of preference or is there something more ?
Old 05-13-2006, 03:56 PM
RETIRED
Joe Bob's Avatar
Differing linkage, setup, parts, preferences different carbs.....chose one.
2012 ML350 3.0 Turbo Diesel
Old 05-13-2006, 03:59 PM
Ok, well i'm an idiot...
I'm not really sure how the linkage on this engine is supposed to go. dual weber 40s...
This is what I got.....
Old 05-13-2006, 04:14 PM
RETIRED
Joe Bob's Avatar
Well you need a support mount/part that mounts to the engine so that the throttle cable shaft can be anchored to and then the cable can pull the bar.
Old 05-13-2006, 04:25 PM
Is the bracket in the first pic for routing the cable too?
also I assume the cable support mount you mention can be home fabricated.. ?
Old 05-13-2006, 05:03 PM
RETIRED
Joe Bob's Avatar
Sorry, missed the bracket in the pic.....I assume the cable end is threaded?
You CAN use a nut on one side with a washer, push it thru a hole in the mount, washer and nut on the OTHER side, tighten and that is where you then decide where to position the arm on the linkage. The arm can move360 degrees in most cases.
It's trial and error on the correct setup.
Old 05-13-2006, 05:16 PM
Joe Sharp's Avatar
Zack: This is the set-up that got Linda 49MPG.
Joe
http://www.clubnarp.com/
My mechanical ability seems to be directly related to my ability to withstand pain.
He who plays with the most toys wins.
Old 05-13-2006, 05:31 PM
Acox914's Avatar
Send a message via AIM to Acox914
zack,
get a CBperformance linkage or a triad....
that bracket that you pictured is wortless on a 914
-Aaron
"60% of the time, it works every time"
Old 05-13-2006, 06:41 PM
So.Cal.914's Avatar
I don't see any end pivots that usually mount to the carbs to hold the throttle bar in place, maybe you just didn't picture them. If not you
will need to look into that.
Old 05-13-2006, 06:58 PM
Thanks guys...
I'm using a new stock throttle cable..
Joe, 49mpg is amazing. I told my dad about that and his jaw dropped.
What's the difference between this linkage and a CB or triad?
The end pivots are hanging on the carbs so they weren't pictured
Old 05-13-2006, 11:40 PM
Joe Sharp's Avatar
Zack: Linda's is the CB.
Joe
Old 05-14-2006, 06:38 AM
