What parts should be kept on hand "just in case". Besides "all of them".
So far: fuses light bulbs points Lately I'm thinkin' a half dozen 11-pin headlight switches...
Dan ----- 1974 914 2.0 in Ravenna Green/Poop Brown |
Throttle cable
Clutch cable Spark plugs Oil |
the correct bulb for the alt warning light. valve cover gaskets. a small screwdriver to pull the idle jets with. a small can of compressed to blow out the idle jets.
![]() k
here? not so much i think. high five!!! |
AAA card
fan belt..... all the above are what should be in the car along with the tools to put them in & on....and a Haynes book so you can see where they go...
Bunch of old cars
Clutch cable is a good idea as Headrage indicated, but you should also have a spare clutch cable trunion that fits into the shift arm, washer and nyloc nut for the end of the cable. These items can be lost on the road if the cable breaks at the pulley while in motion.
Are you looking for a road kit or somethings you should just always have in the garage so you dont have to wait for mailorder.
1973 914-6 3.2 Motronic |
Working on both, really.
I keep a small tool box in the trunk. I also keep a spare clutch cable, speedo cable, spare hose clamps and some bailing wire in the front trunk spare tire. I'm sure you could keep a lot more things but I try to keep it simple and try to keep the car running well so I don't have roadside repairs - but, my clutch cable broke once and so I keep a spare handy.
Vern |
914 Geek
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Forget about the above.. You have injection.... Not Carbs..!! Twystd1
I probably know less than you..... |
Don't forget to have a couple of the round black relays on hand, too.
I GOT YOUR RELAYS..
Pm me in 4-5 days. (Still in Chicago) I will send ya a few... Twystd1
Control Group
YOu can use the relay from the headlight motor if you need a round one on the road
She was the kindest person I ever met |
It's been said before but the best insurance is the parts we have recommended and "AAA"..............
Burn the fire.
"AAA" card
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
oh, then a little screwdriver to adj the idle on the ljet/djet f.i. systems, and a mutlimeter to chase the electrical gremlins, and a spare mps, a spare tps, spare tigger points...the beauty of fuel injection.
k
