GreenWater's Avatar
5 bolt conversion help
I am trying to fit hubs from a 1971 911 onto the spindle of a 1970 914. For the front wheels. I am having a problem finding bearing to complete this job. I have everything else worked out except for the bearings. I just got back from a bearing store and the guy there said that I was out of luck. Is this true? Should I buy the spindle from the 911 too? What is the easiest way to fix this problem? Thanks.
Old 05-30-2006, 02:20 PM
Acox914's Avatar
Send a message via AIM to Acox914
you MUST buy the 911 strut.....
go to 914club.com
it has been discusses ad nauseum.....
-Aaron
"60% of the time, it works every time"
Old 05-30-2006, 02:26 PM
914 Geek
Also check the "five-lug conversion guide" in the Tech Articles section of this very website. Using the 911 struts is the best way to go; I don't know if there is any front bearing that fits the 911 hub and the 914-4 front spindle.
--DD
Old 05-30-2006, 02:54 PM
GreenWater's Avatar
If I buy the 911 strut, will it bolt onto the a-arm and will my 914 shock fit also?
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 05-30-2006, 05:41 PM
djpateman's Avatar
the strut with ball joint will fit.
The ball joints may be the same, depends on the year/type
Shocks, depends on the brand and type of strut
brakes depend on the strut
hubs depend on vented, non-vented rotors.
It would be advisable to get struts complete with the ball joint, shock, hub, rotor and caliper as a set that way you get a known matching/working set.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 05-30-2006, 07:00 PM
Member w/ Title Problems
Jason Porter's Avatar
Do yourself a favor and wait for a deal on a Carrera complete front end!!!
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 06-04-2006, 08:55 PM
Acox914's Avatar
why? the shocks available arent valved right. big deal, get slightly larger A calipers.....
stick with an earlier front end (boge housings) where you can get either 3" (m caliper) or 3.5" (A or S Caliper) mounts and your 914 valved struts SHOULD interchange.....
-Aaron
Old 06-04-2006, 11:48 PM
GreenWater's Avatar
Yeah, It is kind of to late anyways. I have already got a pair of strut housing from a 1973 911. I think these should work just fine for what I want.
84 944
Old 06-04-2006, 11:59 PM
