5 bolt conversion help
I am trying to fit hubs from a 1971 911 onto the spindle of a 1970 914. For the front wheels. I am having a problem finding bearing to complete this job. I have everything else worked out except for the bearings. I just got back from a bearing store and the guy there said that I was out of luck. Is this true? Should I buy the spindle from the 911 too? What is the easiest way to fix this problem? Thanks.
you MUST buy the 911 strut.....
go to 914club.com it has been discusses ad nauseum.....
-Aaron "60% of the time, it works every time" |
914 Geek
Also check the "five-lug conversion guide" in the Tech Articles section of this very website. Using the 911 struts is the best way to go; I don't know if there is any front bearing that fits the 911 hub and the 914-4 front spindle.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
If I buy the 911 strut, will it bolt onto the a-arm and will my 914 shock fit also?
www.Only944.com Porsche parts, Only better, Only944 87 944 N/A 165,000 miles 84 944 Saved by God, because I could not. |
the strut with ball joint will fit.
The ball joints may be the same, depends on the year/type Shocks, depends on the brand and type of strut brakes depend on the strut hubs depend on vented, non-vented rotors. It would be advisable to get struts complete with the ball joint, shock, hub, rotor and caliper as a set that way you get a known matching/working set.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Member w/ Title Problems
Do yourself a favor and wait for a deal on a Carrera complete front end!!!
2023 Ford F-150 Platinum 5.0 Coyote FX4 2019 Toyota Sienna XLE AWD Metal Building Erector, Recovering Porsche Guy |
stick with an earlier front end (boge housings) where you can get either 3" (m caliper) or 3.5" (A or S Caliper) mounts and your 914 valved struts SHOULD interchange.....
Yeah, It is kind of to late anyways. I have already got a pair of strut housing from a 1973 911. I think these should work just fine for what I want.
