Send a message via AIM to nine44
brake line problem
So I'm replacing the brake line that snakes along the front firewall, from the driver's side, and ends up underneath the battery.
I have a replacement metal/steel (?) line to replace it, but after trying to get it in properly this weekend, it's too cumbersome to accomplish without tearing out a lot of things.
Instead I'm just going to cut the new metal line that I bought, so that I can fit in easier, and rejoin it with hosing.
But what kind of hose can I use? I figure the brake fluid will eat away typical rubber hosing.
Old 06-12-2006, 04:15 PM
914 Geek
Umm, that is really not the preferred way to do this job. The reason that there are special fittings on the ends of the brake lines is because there is a lot of pressure in them. It would be pretty challenging to come up with a fastening system that would work reliably with that kind of pressure...
If you're replacing the line, do the job right. Pull the stuff out of the way that needs to come out of the way; otherwise you'll be kicking yourself down the road.
--DD
Old 06-12-2006, 04:44 PM
Control Group
Tobra's Avatar
or bleeding in the crumpled wreck that was you car, with the brake pedal on the floor
Old 06-13-2006, 07:03 AM
