Turn Signal Switch Doesn't Return to Neutral
After I complete a turn, my turn signal switch doesn't return to the neutral/off position. Happens for both left and right turns. What could be the problem?
Thanks,
Old 07-15-2006, 08:50 PM
John Rogers's Avatar
Inside the steering column is a disk shaped piece that has a tab on it so that when the wheel is turned back after a turn it touches the inside of the signal switch. They tend to break off after 30 years or so of use and I don't think they can be bought any longer so manual canceling will be required. If you decide to replace the turn signal stalk you'll see it when you open things up.
Old 07-16-2006, 12:48 PM
