Acox914's Avatar
Send a message via AIM to Acox914
what fuse should i piggyback to run wiper pump?
need to pick up a fused + to run the wiper pump. which fuse should i tap? i have no stereo or heater stuffs, if that makes a difference in which could handle the extra load
AA
-Aaron
"60% of the time, it works every time"
Old 08-31-2006, 10:14 AM
bd1308's Avatar
Send a message via AIM to bd1308
sicne that washer fluid pump needs so many amps, I would run a #0 wire from the battery to your pump.
What exactly is a wiper pump? I hope you didnt backdate to vacuum operated wipers...a RARE option indeed.
According to Google, "I" am Mike Mueller
1974 914 with 72 1.7 and 74 L-Jet system (vroom)
Old 08-31-2006, 11:05 AM
John Rogers's Avatar
One with switched power?
Old 08-31-2006, 11:33 AM
spoke's Avatar
Pick one with an 8 amp fuse and install a larger amperage fuse to account for the extra current of the motor.
Spoke
Find Spoke's LED Products:
www.spokeworksled.com
Old 08-31-2006, 11:42 AM
Acox914's Avatar
924 wiper switch facilitates a pump (i have a space saver tire... so no pressureized tank for me
thanks spoke. ill pick one with an 8
-Aaron
Old 08-31-2006, 02:40 PM
i suggest the one for the cig lighter. high amperage and rarely used.
k
here? not so much i think. high five!!!
Old 09-01-2006, 03:33 AM
