How 2 identify 2L Stainless Heat Exch's
I took some SS heat exchangers off of a 2liter '74 car and put them on Ebay. Someone has asked are they true 2 liter exchangers or are theyoff of a 1.7 or 1.8? I figured if they came off of a 2liter that they must be for a 2L. Help Thanks, Pete
Old 09-12-2006, 03:14 PM
Acox914's Avatar
Send a message via AIM to Acox914
do the ends of the HE's kick upwad a couple inches?
if they are completely flat the whole way... they are 2L
if the ends kick up a few inches, they are 1.7/1.8
it dictates which exhuast hanger, which muffler you can use
-Aaron
"60% of the time, it works every time"
Old 09-12-2006, 04:12 PM
This may be your listing:
http://cgi.ebay.com/ebaymotors/PORSCHE-914-STAINLESS-STEEL-Heat-Exchangers-2-0-L-NICE_W0QQcmdZViewItemQQcategoryZ33630QQihZ016QQite mZ260030389546QQrdZ1QQsspagenameZWDVW
These look like 2.0 exchangers to me. The ends of the heat exchangers (the side that goes to the muffler) will be flat. If they are for 1.7 or 1.8 cars, the ends will curve (noticeably) up wards. The enchangers in this add look flat and not curved - so they are 2.0.
Vern
Old 09-12-2006, 05:53 PM
Hmmm....
I can't get the above link to work but here is the item number: 260030389546
Old 09-12-2006, 05:56 PM
Thanks, That is the correct add. Pete
Old 09-12-2006, 06:55 PM
914 Geek
This first pic is of the 75-76 heat exchangers. You can see that these are a litttle different from the 70-74 style...
This next pic is of a pair of 1.7 SSIs. It clearly shows the "kick-up" near the back of the exchanger.
I don't have a similar pic for 2.0 exchangers, but they pretty much go straight back instead of kicking up like the above picture.
--DD
Old 09-12-2006, 08:15 PM
hey guys, just for clarification - you can use the 1.7 HE's on a 2.0 as long as you use the 1.7 muffler and hanger correct? what would be the downside to this?
Racer Girl
73 914 2.0
57 Vette (ok, actually dad's, but i get to play with it)
Old 09-12-2006, 09:05 PM
Conrad W Peden's Avatar
Not sure about the SS exchangers, but when comparing diameters of tubing I could fit the pipes of my 1.7 inside the pipes of my 2.0
Much smaller
We'll be having an ISO9000 audit soon.
I've divided our preparation tasks into two groups: Unethical and Unproductive.
Old 09-12-2006, 10:21 PM
914 Geek
The SSIs are evidently the same diameter for the 1.7 or the 2.0 versions.
Rcrgrl is correct, as long as you use the matching muffler and muffler hanger (and muffler gaskets) you can switch between the 1.7 and 2.0 styles with no problems. Even the heater parts should all fit the same, as well.
Note that the 75-76 exhaust uses significantly different heater parts, though.
--DD
Old 09-13-2006, 07:17 AM
gee, luckily i have a 75 2.0.
thanks dave!
Racer Girl
73 914 2.0
Old 09-13-2006, 12:50 PM
hardflex's Avatar
I had a 1.7 motor bored to 1.8. Someone gave me a pair of factory 1.8 exchangers, so I put them on. The difference in flow was very noticeable, reved much easier too. I would think a 2.0 would be pretty choked with a 1.7 exhaust. The SS are all the same size i think, though, so it wouldn't matter
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 09-13-2006, 12:54 PM
914 Geek
The factory 1.8 exchangers would either be identical to the 1.7 ones (if the 1.8 in question was a 74 1.8) or identical to the 75-76 2.0 ones (if the 1.8 in question was a 75+ one). I'm not sure what you put on, but I'd be surprised if there was much improvement going to a stock 1.8 exhaust.
--DD
Old 09-13-2006, 04:53 PM
hardflex's Avatar
there was a noticeable difference in size between them, the size of the 2.0's but they had the kickup at the back. I know they weren't 2.0's because I had to change the muffler setup when I took them off.
They're off the car still now, so I can take pics of the difference
Old 09-13-2006, 07:03 PM
914 Geek
Did they look like my pic above? Those would be SSIs--the 1.7 SSIs and the 2.0 SSIs are the same diameter as each other, and both are larger than the stock 2.0 exchangers.
--DD
Old 09-13-2006, 11:17 PM
hardflex's Avatar
Here's what I took off, compared to another set I had. You can see the noticeable difference in the size of the tubes. ID of the larger one's is about 1.33", the smaller ones about 1.17"
Old 09-16-2006, 05:40 AM
