How to isolate the CSV
Living in OZ I dont think the cold start valve is necessary.What is the best way to isolate this valve and how would that affect performance?
Geoff.
Old 10-22-2006, 02:08 AM
hardflex's Avatar
disconnect the fuel line connection. It will only affect starting at freezing temps, other than that, you won't miss it a bit.
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 10-22-2006, 06:12 AM
Thank you Hardflex thats what I thought.I noticed on another thread that you were querying black smoke out of the exhaust.My car is a '73 2.0 litre and I am getting some black smoke out the exhaust I presume that the car is idling rich is that correct?
Old 10-22-2006, 03:26 PM
hardflex's Avatar
Yes, black smoke indicates a rich mixture.
If your cold start valve is leaking, that could be causing the richness. When mine went out, it would bleed the fuel line pressure into the intake plenum, and was real hard to start. You had to treat it like a flooded carburetor and floor the throttle .
Also check the MPS to make sure it holds vacuum. If it doesn't, it would be send full throttle fuel supply all the time.
Old 10-23-2006, 05:49 AM
RETIRED
Joe Bob's Avatar
If you still have the stock FI....the adjustment knob on the brain will correct idle mix only. Best to use an emission tester while doing so.
A bad MPS can also be an issue.
2012 ML350 3.0 Turbo Diesel
Old 10-23-2006, 10:19 PM
Re: How to isolate the CSV
Geoff.
Geoff,
I thought I'd told you, John S. said the CSV valve was leaking
on that car! I would check it out. Just clicked in my head.
Jeff
Old 10-27-2006, 11:20 AM
