Post The computer
I got a 74 2.0 engine that had been sitting in a closed garage for around 5 years with no preservatives. I completely rebuilt it and the only component that isn't new or proven good is the the computer. I started the car yesterday for the first time and the fuel pump does not turn off as it should when you just turn the key without starting it. I have read that the timimg for the fuel pump to turn off is the computer's responsibility. Does this point to a bad computer or could it be another single component???????? The only way i know to check the computer is by pulling every single wire from the computer and making sure they are good. Any other diagnostic tricks for the computer??????
Old 07-14-2001, 08:35 AM
914 Geek
Porsche Crest
Could be the pump relay, or possibly some of the wiring. Or the ECU.
The following article describes the fuel pump control system in detail: http://www.914fan.net/fuelpump.html
Dig through it and you should be able to find the cause of your problem.
--DD
Old 07-14-2001, 03:33 PM
pbanders's Avatar
Send a message via Yahoo to pbanders
Post
I have a fuel pump circuit checkout flow chart at:
http://members.rennlist.com/pbanders/FPChecklist.htm
Brad Anders
Old 07-15-2001, 03:48 PM
