Danny_Ocean's Avatar
How the heck...
...do you change/adjust the alternator belt on a 914-6 conversion?
I did a search, and it appears cutting an access panel between the seats is possible, but I'd rather not.
Old 06-28-2007, 08:42 PM
Brother's Avatar
drop the engine.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 06-28-2007, 09:17 PM
Originally posted by Brother
drop the engine.
Uh-uh...ain't gonna happen. I'll cut the firewall before I do that.
Old 06-28-2007, 09:34 PM
Send a message via AIM to mduquette
Cut the back oanel and make an access port. Aquire a piece of sheet 2" larger overall then the cut out and use aircraft fittings to make it easily removable.
>M<
Old 07-06-2007, 04:38 AM
cut an access hole and make a panel to fit over it.
an aluminum panel fits over the hole. You can either use nut-rivits, or tack weld some nuts to the back side so you can bolt the cover in place.
Old 07-06-2007, 06:48 AM
Control Group
Tobra's Avatar
Nice solution, you could put a bead of silicone or some weatherstrip around periphery to seal it too, in case you drive in the rain
Old 07-06-2007, 11:17 AM
