Post Seatbelt/starter relay on 74 1.8
Hi all,
what is the correct way to bypass the seatbelt-to-starter "relay"? I have a 74 and under the driver's seat I see a dangling wire. The PO told me he disconnected it so the car can be started without the seatbelt in place. Is this OK? (just disconnect it?) or is there another way?
Old 07-25-2001, 09:33 AM
Serge914's Avatar
Post
I also bypassed those relays on my 74 1.8L. You just need to connect together the 2 heavy yellow wires and discards all the others ones. You can look at the electrical schematics in the Haynes manual, the European version doest't have those relays.
Old 07-25-2001, 12:40 PM
Serge914's Avatar
Post
Oh by the way those relays are under the passerger seat.
Old 07-25-2001, 12:43 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Porsche Crest
Yup, that's how you do it. A less-permanent (and more failure-prone) way to do it is to make up a jumper wire to plug into where the relay used to go that connects the two yellow wires.
A more permanent way is to solder or crimp the two wires together. Make sure you use shrink-tubing if you do either of these--you really don't want water getting in and messing up the connection.
Finally, I suggest leaving all of the other wires in place. There are other systems that get their power "daisy-chained" off of the relay. The relay isn't necessary, but the power goes to the connector, and from the connector it also continues to the other system. If you really want to get rid of the wires, then splice together any wires that go to a single connector. The ones that are "solo" you can get rid of. Just make sure none of the cut-off wires can get grounded, or you'll have some very strange problems.
--DD
Old 07-25-2001, 01:10 PM
funnyguy's Avatar
Send a message via ICQ to funnyguy Send a message via AIM to funnyguy
Post
this 74 2.0 i'm going to buy starts with the seat belts unlatched. i didn't knwo there was a relay, is this bad ?
Old 07-28-2001, 01:28 PM
Administrator
Porsche Crest
It could just mean that the sensors on the seat belt buckles were unplugged. That fools the relay into thinking the belts are fastened.
--DD
Old 07-28-2001, 02:21 PM
Post
Just went through this today! Be warned, the heater blower and other accessories are controlled by that logic switch. The PO of my car "jumped" the seatbelt switch as well, and removed the logic switch. Nothing out back was working. See my post of 7/27/01 about aux heater blower. "jumping" may cause you some of the same problems.
Old 07-28-2001, 03:21 PM
