Post FI part locations
Hi All,
I am in the process of re-installing the FI after my renewing of the top end. The PO had removed and installed Dell's but since living in CA will need to get FI installed. My question is this, I have all the components located and bolted in exept I have no idea where the decel valve is going to be located. I know I can pretty much put it anywhere since I only have to run the vac lines to it, but would like to have as stock looking as possible. Any help would be great and if a picture could be had "hint" I sure would be greatful.
Thanks,
Brian
'74 1.8L in resto
Old 08-04-2001, 09:20 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Post
If you have the Dels and need any FI stuff I have a complete 1.8 FI system I might swap you. Steve
Old 08-05-2001, 08:04 AM
DSPTurtle's Avatar
Lightbulb
There should be a bracket near the battery that will hold your decel valve. I believe it sits pretty much underneath the charcoal canister on the passenger side of the engine compartment.
Old 08-05-2001, 08:49 PM
