Question 2.0 Compression ratio and Performance
OK, Im using a "EA" 1.7L Block, 2.0L stock Crank, 94MM COFAP Pistons, 1.8L FI Heads, Can anyone out there tell me the compression ratio? How well will this combo perform with a Engle 2202 Cam(278 Duration and 410 Lift) and dual 44 Webbers?
Duane
[This message has been edited by piperpilotduane (edited 08-07-2001).]
Old 08-07-2001, 03:28 PM
Post
To calculate compression ratio, we need 3 things:
*Cylinder head volume, measured in CC
*a measurement taken from TDC to the top of the cylinder, measured in thousandths of an inch
*The amount of "dish" in the top of the pistons, yours should be 7cc, if they are cofap..
Until we get this, there is no calculations that can be made..
I would SERIOUSLY think about adding that Engle cam to file 13, and grabbing a Web Cam!
Jake Raby
Raby's Aircooled Technology
http://www.aircooledtechnology.com
Old 08-07-2001, 03:49 PM
roadtrp204's Avatar
Post
If you have Microsoft Excel this is a nice spread sheet to figure compression.
http://www.pelicanparts.com/914/technical_specs/914_compression_ratio.htm
I measured the dish on the Cofaps I had and it measured at 7cc.
Chris
75 914 2.0L
Old 08-08-2001, 06:36 AM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Post
See: www.aircooled.net/gnrlsite/resource/specgeninfo/calcs.htm Steve
Old 08-08-2001, 06:45 AM
Post
Jake - you've made me feel really good about my purchasing a Web Cam instead of anything else. Question that I posted a while back with no definative answer; I have enlarged my inlet valves to 48mm and exhaust to 38mm. This will be on a 1.8 case, 2.0 crank and rods, 96mm 2.0 pistons and 1.8 heads. Did I screw up? I hear you are the 914 motor expert.
Old 08-08-2001, 09:32 AM
