ferrarislayer's Avatar
76 914 trans issue
the 76 914 is stuck in gear how do i get it out of gear? i had to put a new oil cooler on the engine because the owner of the car messed the old one up some how.. and when i hooked everything up and went to start the car its stuck in reverse.. it was shifting fine before hand .. please HELP ME!!!! please email me asap with a solution..
Old 11-15-2007, 05:23 PM
PLEASE HELP!!!
Old 11-15-2007, 08:24 PM
does no one know?????
Old 11-16-2007, 12:00 PM
how do i align the gears without disassembling the whole transmission?
Old 11-16-2007, 03:22 PM
jhora's Avatar
First thought is the linkage....
If the trans was shifting fine before the removal of the engine first check your shift linkage...
see if you have everything correct there on the reinstallation....
You can remove the linkage at the trans and see if you can shift in and out of gears...you can do this by hand...little stiff but can be done by hand...
Old 11-16-2007, 05:16 PM
Rrrockhound's Avatar
How did you replace the oil cooler? Did you remove the engine?
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 11-16-2007, 05:27 PM
914 Geek
As suggested, check the linkage. If everything is OK, disconnect the linkage at the transmission end and try to manipulate the gear selector at the transmission directly. If no joy, unbolt the side shift console (where the gear selector goes in) from the trans case. Drain the oil first, unless you want to dump it all when you unbolt the console. Try moving the shift rails directly. If no luck with that, it's likely time to disassemble the trans.
Hopefully one the folks who knows more about the insides of those things will pop up and correct me if I'm wrong about any of the above...
--DD
Old 11-16-2007, 06:19 PM
jhora's Avatar
Dave you're dead on...I think the linkage reinstallation is the issue...just doesn't seem reasonable for the trans to lock up if it was shifting just fine before the cooler replacement..
If the trans if locked up it is a heck of a lot easier to work on the guts with it out of the car....
Old 11-16-2007, 08:43 PM
