I cannot get my engine lid to fit well at all. Is there a secret? I have moved it around as much as I can. The lid wants to hit the rear trunk lid.
Shane |
Try adjusting the rear trunk lid. It's easier to mess with that than the engine lid IMHO. An extra set of hands to wrestle the trunk is a good idea, good luck
![]() Nathan ------------------ '73 2.0 914 |
Sometimes the "L" brackets that the engine lid bolt to break their welds at the top and bend rearward, causing a clearance problem with the lid-to trunk clearance. I'd check those welds
I had the same problem once. The passenger side L-bracket cracked at the fillet and bent downward. It shifted the lid to the point where it wouldn't close unless I pushed the lid forward and then downward. I ended up removing the lid, had my buddy re-weld the bracket and then we put the cover back on. The cover didn't want fit well at all so I made the slotted holes a bit bigger on the engine cover. Two sets of hands was the key though. I just couldn't get it to fit by myself.
