worn tail shift rod & shift shaft
Finally decided to investigate sloppy tail shifter and figured I'd find worn bushings. Instead, I found extreme wear on the rear shift rod end and moderate wear on the shift lever shaft...see pics. Seems I could fill the worn areas with weld as shown in the pics and shape as best I can, or look for used parts. Anyone with experience with this, or pics showing what un-worn parts look like for reference to reshape mine?
Ed
'74 914 V8
'70 914
Old 04-23-2003, 07:40 PM
Biggy72's Avatar
wow that's terrible. Looks like if you wouldn't have done something pretty soon it woulda just broke off. I don't know what to tell ya bout fixing it, but I sure hope that's not party of my shifting problems when I get around to fixing em
Black 72 1.7 914
http://www.pelicanparts.com/gallery/Biggy72/
WSU Formula SAE
Drivetrain team leader/ Suspension team
http://www.mme.wsu.edu/~sae/
Old 04-23-2003, 08:06 PM
canna change law physics
red-beard's Avatar
How about some replacement parts? I have lots of tailshift stuff hanging around. PM me and we'll work something out.
James
James
Red-beard for President, 2020
Old 04-23-2003, 08:18 PM
Speedo959's Avatar
I found this old thread while searching. You mean to tell me there is no bushing between these two points of contact? I am rebuilding my tail shifter and was wondering if I was missing a bushing or if this is the design. Seems rinky dink to me not to have some sort of bushing.
70 911T
71 914
89 BMW R100GS
Old 12-16-2007, 09:41 PM
red-beard's Avatar
There was an article from years ago, about brazing more material, back onto the parts to reduce the slack.
The best choice is to find a side shifter, shift rod and passenger compartment gear selector and replace.
James
Old 12-17-2007, 04:18 AM
Speedo959's Avatar
It looks like for now, I will be doing some welding.
70 911T
71 914
89 BMW R100GS
Old 12-17-2007, 06:10 AM
