RustyWa's Avatar
Question Engine lid grille color.
The engine lid grille looks a little tired on my car ('75 2.0). Is this something that could be 'rattle-canned' with good results?
What finish of black was the original? Glossy, semi-, satin?
Also, same question on rockers and valences as long as I'm thinking of painting..
Old 08-24-2001, 10:45 AM
Porsche Crest
I would call it Semi-eggshell.
Will spray paint will ever get hard enough to stand a normal cleaning? Hmm..
The grill tends to have a lot of surface rust so I would give it a good sanding first. I tried a normal spray primer on it and I had to sand it all off because it created puddles of primer on the edges. I was able to use an engine primer (VHT). Engine primer goes on very thin and close to powder.
If you really want to do a spray can job
mist it as far back as you can. Of course someone will say only Wurth paints will do
NOT AN ENDORSEMENT.
http://www.eastwoodco.com/cgi-bin/sgsh0101.exe?PGN=1&SKW=DIV_00%20satin&!UID=2001082417485158&FNM=20
SAVE $2.99 OVER INDIVIDUAL PRICING!
Price: $ 19.99
TRIM PAINT AND SELF ETCH PRIMER KIT
item-no 10042 Z
Duplicate or restore the OEM finish on exterior black-trim surfaces. This semi-gloss paint adheres to steel, stainless, aluminum and even chrome surfaces. For improved adhesion, use a thin coat of self-etching primer.
-Rich
Old 08-24-2001, 03:01 PM
bowlsby's Avatar
Post
The black is officially called 'satin' which is duller than semi-gloss, shinier than flat or matte. Look around, its not too hard to find, don't get semi-gloss.
Old 08-24-2001, 03:28 PM
HMeeder's Avatar
Post
I'm with Bowlsby. I have used Rustoleum Satin Finish with great results. They think that it's for steel and iron patio furniture (have pictures of patio chairs on the can) and it comes in forest green and black. I chose black. I also used this to touch up and paint the rockers, rear valance and front chin.
While painting car body panels seems faintly 'trailer park custom' to me, it came out great, and I can touch up those highly vulnerable areas whenever I want.
Good Luck!
Herb
'72 1.7 Tangerine 'Teen
'74 2.0 Red Rustmobile
Old 08-25-2001, 07:42 AM
DDS DDS is offline
Post
Mar-Hyde is good stuff too.
Old 09-02-2001, 07:34 AM
RustyWa's Avatar
Post
Did you guys remove the grill to paint it?
Also, a few of my plastic chromed letters have spots where the chrome is bubbling up. Can you chrome paint these with good results?
[This message has been edited by RustyWa (edited 09-02-2001).]
Old 09-02-2001, 09:59 AM
