Oil cooler leak
Not sure what I did but I know it wasn't right. I just put my engine back in about 200 miles ago. Now I seeem to have an oil cooler leak.
So on to my question: Can I remove the fan housing and tin to get to it with the engine still in the car?
Old 02-04-2002, 07:26 AM
You can remove the fan shroud and all the assorted junk to get the cooler seals changed, but why do you need to? If the oil cooler is leaking, from under the car, you can remove the bolts holding the cooler, and slide the cooler to the front of the car. The seals will just fall out. Then take some grease and a big flat blade screwdriver and stick the new seals in place. Then slide the cooler back in place and install the nuts.
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 02-04-2002, 08:24 AM
Hmm
Well I looked at that method. Either way it is going to be a pain. I can see the two nuts but not the third one Guess it will be by feel. I will let you know how it goes.
Old 02-04-2002, 08:40 AM
ShawnO
Guest
Posts: n/a
Unhappy
Sorry to hear it Joe. From what I've read you can do it without dropping the motor. Looks like it would be pain but probably better than dropping the motor.
However, if you made the mistake I did (due to an error in the Haynes manual) and installed washers between the oil cooler and the case then you might have to pull the motor to remove the washers.
Let us know how it turns out.
Old 02-04-2002, 08:44 AM
Clay Perrine
95 BMW 540i (Inga)
Old 02-04-2002, 08:45 AM
You can even drop the cooler with this method. You follow the same procedure, then use a pair of needle nose vice grips to unscrew the studs, and then just lower the cooler.
You can then add the missing washers and reinstall the cooler.
Clay Perrine
95 BMW 540i (Inga)
Old 02-04-2002, 08:48 AM
ShawnO
Guest
Posts: n/a
Now you tell me...
Old 02-04-2002, 08:52 AM
Va914's Avatar
How do you test for leaks in the oil cooler?
Kerry
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 02-04-2002, 12:39 PM
Don' bother. If you even suspect the cooler is leaking, buy another. It's cheap insurance. You can have a partially clogged one too, and that wil affect the oil temp badly. You can get a new cooler from our sponsor. If you find a leak, you can't do a thing about it execpt replace it.
Clay Perrine
95 BMW 540i (Inga)
Old 02-04-2002, 12:45 PM
Va914's Avatar
Well I removed the oil cooler to do alittle bit of engine cleaning and to replace the pushrod seals. I figured since it was out get it tested.
I'll check the prices on PP for a new one.
Kerry
914-6 in the Werks
Old 02-04-2002, 01:24 PM
914 Geek
We have a tech article on this very subject. Take a look in the 914 Tech Articles section. It can help out in a lot of cases.
--DD
Old 02-04-2002, 04:29 PM
