Rrrockhound's Avatar
What is the deal with this rearview mirror?
I guess it's a good sign that my car is so sorted out that all I have to worry about is the mirror, but my inside mirror is making me bat***** crazy. It wobbles and shakes because it doesn't seat properly into the windshield mount. It's like the arm is too big for the mount. Was there more than one factory mirror or mount on the 914? Is there a way to remove the mount without cracking the glass?
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 06-19-2008, 06:36 PM
Owned every color VW made
R_Davis's Avatar
Rrrrock ... SuperGlue?
Yes; I listen to Hip-Hop ... At every single stoplight & gas station!
'72 1.7 (The Beverly) a la 'The Rockford Files'
'99 Chevy Pickup
'59 Les Paul
Old 06-19-2008, 07:11 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
there were at least two. I know from my own experience similar to yours
Old 06-20-2008, 01:15 AM
I'm thinking JBWeld.
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 06-20-2008, 06:47 PM
R_Davis's Avatar
HA! JB Weld would work .. of course ... but that is so ... ah ... permanent.
Rrrrock ... is there a way to put a piece of teflon tape or a wedge of some sort into the bracket. You won't have to mess with the mirror until it falls off and you have to glue it back on anyway.
I still recommend a drop of Superglue
Best regards,
Rick
'99 Chevy Pickup
'59 Les Paul
Old 06-20-2008, 07:54 PM
914 Geek
Look at the bottom of the mirror arm. There'll be a small round hole, with a flat-head screw up inside it. The screw holds the arm onto the base. You may be able to tighten the screw, or remove it and pull the arm off so you can wrap something around the arm where it goes into the base.
--DD
Old 06-20-2008, 10:15 PM
I've tightened the screw as much as I can without stripping it, and I don't want to strip it, because I once cracked a windshield trying to remove a glued-on mount with stripped threads. I now wish I had just mounted a nice, modern rearview mirror, but no, I had to go for the original look.
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 06-21-2008, 12:07 PM
