Send a message via ICQ to WarrenS
Post backup light switch
Is there a substitute for the 914 backup light switch? I've been told there is a replacement available from either VW or Volvo. It would be much easier to get one of those rather than track down the exact Porsche part.
Old 10-22-2001, 07:23 AM
914 Geek
Porsche Crest
"Hello, Pelican Parts? Could you send me a backup light switch for my 914? Yeah, here's my address and credit card info."
Now, wasn't that easy??
Plus you get to support this BBS that way.
888/280-7799
--DD
Old 10-22-2001, 08:50 AM
philinjax's Avatar
Post
The Porsche part is 914 613 541 02. Your switch is likely not bad, it's the actuating
pin stuck in the tranny that wears outon the tip that rides an internal cam. This shortens the pin thus failing to fully actuate the switch. It's called a "cam follower". All it is is a pin with a grove and little snap ring in it. The part no. for this is 901 303 017 01.
I have replaced this pin with a 7/64 drill bit, ground off flat on the tip. I then ground a grove in the pin and installed the
little snap ring off the old part. Works great.
philinjax
Old 10-22-2001, 08:54 AM
Post
Since we are in the same neighborhood, I was installing the "expansion bolts" on my son's 901 xmission on Saturday. Before I could get to the 80 ft lbs Haynes says I need, the bolt "expanded in half". To my surprise, when I did the other side, the same thing happened. Is that a misprint in the manual, or are the bolts only good for one use?
Old 10-22-2001, 09:06 AM
Post
That's my plan if I don't find a suitable replacement Dave... Pelican Parts is first on the list after the local shops. It's the expense and time for shipping to Nova Scotia from California that is making me look nearby first.
I like your idea Philinjax. Have to pull the old one out this evening and see what's happened inside there.
Is it ok to drive with the switch removed from the transmission?
Old 10-22-2001, 09:43 AM
philinjax's Avatar
Post
According to the manual (Haynes), the drive shaft flange expansion bolt torque is 25-29 foot pounds. philinjax
philinjax's Avatar
Post
I think the tranny will leak or throw oil if you leave the switch off. philinjax
Old 10-22-2001, 09:46 AM
Send a message via AIM to JP Noonan
Post
If Iremember right the switch had oil on it when I removed mine. So It will leak, how much I don't know.
I personally would get the right part, having the pin wear out is better than a hard as nails drill bit wear through the transmission part that it rides on. I'm guessing the drill bit is a few Rockwells harder than the pin.
Old 10-22-2001, 09:38 PM
