norustscott's Avatar
Question ECU question
The little Bosch sticker on the outside of my ECU is no longer intact...The question is...Is it the correct ECU for a 1973 2.0l...
Is there any indentifier inside of the unit?
As you may or may not know...The 73 2.0l has a specific ECU/MPS/TempII sensor with resitor, setup. I have always had problems with the D-jetronic...who has not? I may be able to set up using a later ECU, however, the exact bosch part number on the spare is also worn away...So, Can you determine what unit it is from data on the inside of the case?
Thanks, Scott
Old 10-23-2001, 04:45 PM
bowlsby's Avatar
Post
I *think* there may be a series of numbers stamped into the side of the metal ECU case...?
Please verify and post them if they are...
Old 10-23-2001, 04:50 PM
Post
No good part numbers...However, there are numbers and letters:
On the side next to the fire wall...you find the letters DB in a circle
On the bottom of the unit...the letters RT in a circle with the number 128
The other unit in the garage has just teh number 512 stamped on the side...
That is it...
Old 10-23-2001, 05:21 PM
Send a message via AIM to JP Noonan
Post
Paul B. Landers is the man to talk to. Do a search to find his e-mail, pblanders I think
Old 10-23-2001, 05:41 PM
Post
One step ahead...I thought I would give the rest of us D-Jet novices a shot...Once I find out I will post results...I can't tell you how many times I passed up an ECU at the swap meet because I could not find a part number...@ five bucks a pop I should have bought all of them....Thanks Scott
Old 10-23-2001, 05:48 PM
Post
From my parts manual, the p/n for a 2L appears to be 039-906-021 (from engine No. GA-0-006-766 or from engine No. GB-0-007-402). Hope this helps
Old 10-23-2001, 06:16 PM
bowlsby's Avatar
Post
PAul Anders site is here:
http://members.rennlist.com/pbanders/djetparts.htm
Responding to the post above the GB code engines were european-only 1.8L cars with carbs....no ECU.
Old 10-24-2001, 08:48 AM
pbanders's Avatar
Send a message via Yahoo to pbanders
Post
I responded to Scott via email, but I thought I'd post this for general interest. If the label is missing, ID'ing the ECU can be difficult. Some, but not all, have a sticker on the main board next to the edge connector. Use a small mirror and you may be able to see it. I don't recommend opening the ECU - the metal tabs that hold the lid on are easily fatigued after bending and snap off easily.
Brad Anders
Old 10-24-2001, 08:51 AM
Post
I will pull the connector and check for the sticker..thanks to all...scott
Old 10-24-2001, 10:15 AM
Post
Ref. the GB engine. According to your reference, the GB is listed as a non-US:
"GB 2.0L non-USA 0 000 001 to ??"
Which matches the info in my Factory Parts Catalog.
Old 10-24-2001, 06:15 PM
bowlsby's Avatar
Post
OOpers...busted...I should trust my memory so much...
You're right 2.0L, not 1.8L.
Carbed tho and only in Europe...
Old 10-25-2001, 08:25 AM
Post
Yes...There is a sticker on the mother board near the connector surface...and it is a part number. Unfortunatly, the number is for the 1976 2.0l. The 1973??? ECU did not have the sticker. The mystery of My 73 2.0l continues...I have found a reciept from the PO indicating that a used ECU was purchased and installed. The reciept indicates the the unit is a CU-13x. I think that is a number to designate the unique 73 ECU...
So, Like indicated before..some will have the sticker...others may not...
Old 10-26-2001, 09:19 AM
914 Geek
Porsche Crest
Jeff, the GB is the European-spec 2.0, and used D-jet EFI.
AN is the European-spec 1.8, and was the only four-cylinder 914 to be offered with carbs.
--DD
Old 10-30-2001, 10:51 AM
