neilca's Avatar
901 synchro hub for first gear
Here is a tough question I have been noodling for a week, still cannot figure out,
Why is the synchro hub on the first gear of a 901 box different from the other hubs? They all use the same synchronizer. Can you use 2-5 hub on the first gear?
Thanks,
neilca
Old 04-21-2009, 06:41 AM
No, 1st gear only has one brake band. Obviously it works only in the forward / upshift direction.
It might work if you swapped in a hub. Let us know as I got a box of hubs .
Old 04-21-2009, 07:00 AM
neilca's Avatar
I decided to go ahead and try replacing my first gear synchro hub with one from a "N" gear set I had left over. Everything went fine. I used a bearing puller and a press to remove the old hub and then used the press to put the new hub on, no problem. I used the two spring internals and reassembled the box. shifts fine.
I am guessing Porsche used the unique synchro hub on first to make it easier to engage the gear from a stop. The other gears get engaged at speed. My car is a race car so I am not too concerned hoe easy first is to engage, I will only use it in the pits.
I have not driven it yet, I will follow up with how well it engages while stopped.
neil
Old 04-23-2009, 06:11 PM
