airkooled05's Avatar
Thumbs up Question Re Replaced Throttle Cable
We just replaced the throttle cable on my 914 2.0 with carbs . Works fine but sometimes when I go into third gear it hangs up and the engine continues to rev . Correct cable was kind of expensive so I wont drive it until I figure this out as I dont want to replace it again real soon . Thanks for your input
Old 07-17-2009, 03:21 PM
Recovering dismantler
neil30076's Avatar
You probably got the throttle cable snagged up with the shift linkage in the tunnel - try again!
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 07-17-2009, 04:57 PM
914 Geek
...Or with the clutch cable. Very common to do that; look up at the front of the center tunnel to check the cables.
--DD
Old 07-17-2009, 06:34 PM
Great input
thanks , it seems to be fixed . Much obliged to both of you
Old 07-19-2009, 08:42 PM
