996???
I wonder if this would fit in our cars??? A small hole...SteveStromberg, don't you know how to TIG weld? Somebody has gotta take a chance on this!!! I wish I had the skills to fab this thing in.
SOMEDAY!!!
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
don't know the diffrerence in size but this car has a 993 turbo engine in it.
You might have a little trouble finding space to put the radiators to cool the 996 engine though. I guess you can set it up similar to the V8-conversions.
It certainly doesn't hurt to dream about more horsepower...
Xerxez 73 914 2.0L Sunflower Yellow/Blk/Blk 70 914-6 White/Blk/Blk |
I have a new theroy about water cooling. You can get a custom radiator made that fits below the bonnet lid. Then route your hoses, put in an over flow tank (with a check valve) and then add two fans that blows are into the compartment. It should have enough volume to cool a big engine. The only thing I'm not sure of is the ever questionable clearance issue.
914 Geek
"A small hole in the case"... Uhhh, caused by what, exactly? One of the rods exiting the case at a high rate of speed, perhaps?
DSP, I suggest sticking to a 993 motor or smaller. That's more power than you can effectively use in a 914 anyway--300+ HP with oodles of torque is more than enough to convert your tires into smoke. (Ask me how I know--WHEEE!!!) The extra hassles won't be worth it. newestone, that car looks like it has stock fenders. Which would limit it to 205, maybe 225 (if the fenders have been carefully modified) tires. Which is laughably inadequate for a 400 HP 993TT motor. I know for a fact that 225s are not enough for a 993 non-turbo motor (see the above paragraph)--they'd just be ridiculous for the twin turbo... I'd also be very worried about brakes in that thing. Unless there are five-lugs hiding behind those baby-moon hubcaps, that thing has stock or near-stock brakes. Nowhere near enough for 400+ HP and a few hundred extra pounds. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Germain:
Something like this. I have 2 fans (2 speed) in my car, always run cold.
1972 914 914-6 gt look chevy 2.8 v6 (928 engine project) 1974 914 916 Look (3.2 webers engine project ) 1984 944 Auto 550 Spyder (replica) 914 side trans 2.2 type 1 1957 R50 1981 R100RS 2000 K1200RS My Page |
