75 914 2.0L exhaust
Will the 74 stainless steel aftermarket heat exchanger & muffler setup fit (without modification) my 75 2.0?
Steven Storch
Old 04-03-1999, 10:35 AM
914 Geek
Yes, it should. The exhaust ports are the same between the 73-74 and 75-76 2.0s.
You will probably need to buy a muffler bracket (hangs off the end of the tranny, connects to the heat exchanger/muffler joint) from a 73-74 2.0 specifically. You may be able to adapt the 75-76 one to work; I'm not sure.
Good luck!
--DD
Old 04-05-1999, 11:27 AM
We need more information on this one. What muffler and exhaust was on the 74? Stock? 2.0? You can distinguish the 2.0 muffler in that it has a straight (not upward bent) run from the heads. They will lie flat on the ground. This put the 2.0 muffler lower or further away from the trunk floor. Heat problem I think. That's the reason the muffler hanger for a 1.7 or 1.8 will not work without modification.
Old 04-05-1999, 05:50 PM
