rfoulds's Avatar
Unhappy mounting bumpers
I got some used chrome bumpers for my '74 (yeah!) but after cleaning them up, and putting the new rubber tops on, I found the threaded holes or nuts that are welded to the back are completely stripped and won't hold the bolt. I guess I will be taking them to a machine shop to weld a nut on, or to thread what is left.
Unless anyone has a better idea? I am open to suggestions.
Randy Foulds, La Quinta, CA
Old 12-10-2001, 09:59 PM
Senior Member
Hello
Helicoils ?
Icky corner to weld. best is drill out the restnut and place a new stainless steel nut on that place and hard solder it.
If everything brakes you can place a nut via the open horn grille.
Grüsse
Old 12-11-2001, 09:55 AM
rfoulds's Avatar
I ended up drilling out the rusted out holes, welding two nuts to a 1" x 5" plate, and placing that behind the bumper mount. No need to actually fasten it to the bumper, since I will use duct tape to hold th edog bones in place while I mount the bumper anyway.
Old 12-13-2001, 10:59 AM
Otto's Avatar
rivet nutter
We work on Porsches here at OTTOS and have been using a rivet-nutter for making or replacing captivated nuts. They come in sizes from 3mm to 14mm. It is just like a rivet, except it is threaded on the inside. If I ever figure out how to use a digital camera and down load it on the web, you will see it at this site. Like when we do the fuel pump relocate, we drill two holes on the front firewall and use the rivet-nutter to make capitaved threads that we can mount the fuel pump mount to. OTTO
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 12-13-2001, 05:59 PM
