Help Identifying this Brake Caliper
My 914 when I bought it already had a "911 front suspension/brake conversion". I'm a little new to the Porsche thing so I was wondering if anyone here could ID these calipers so I can get some rebuilt units. Sorry for the crappy shots but I was running out of daylight.
Old 07-28-2010, 06:37 PM
racer's Avatar
Can't identify, per se, but measure the spacing between the mounting bolts.. If 3.5" they are "later brakes" if 3.0", they are earlier brakes.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 07-28-2010, 06:59 PM
racer's Avatar
Per pelican parts:
At Pelican Parts, we offer a wide variety of brake pads, whether it's for your stock Porsche or for more of a track purpose, we can match the right brake pad to the right application for you. The "M" Brake Calipers are a small, 2 piece cast iron caliper and measure approximately 75mm between the mounting holes. The "A" Calipers are a large 2 piece cast iron caliper and measure approximately 95mm between the mounting holes. And finally, the "S" Calipers are a large 1 piece aluminum alloy caliper and measure approximately 95mm between the mounting holes. Can't figure out what's best? Just ask us, and we'll make a recommendation for you. Check out our Pelican Technical Article on Brake Pad Replacement for the low-down on the best way to change out your pads
Past:
Old 07-28-2010, 07:02 PM
3.5" Hole spacing, what constitutes "later"?
Old 07-28-2010, 07:06 PM
Originally Posted by racer View Post
Per pelican parts:
Thanks, that helps a lot. So in theory, any "A" caliper would work with this setup?
Old 07-28-2010, 07:08 PM
914 Geek
M calipers: Ferrous (a magnet sticks to them)--either steel or cast iron--with 3" mounting bolt spacing.
S calipers: Aluminum (magnet will not stick) with 3.5" bolt spacing.
A calipers: Ferrous with 3.5" bolt spacing.
The S and A calipers are pretty close, and I think are interchangeable with each other. The M calipers are pretty much it if you have the 3" mounting bolt spacing. But frankly, they're quite good enough for anything but really heavy-duty abuse.
--DD
Old 07-28-2010, 09:31 PM
gearhead
Just send them off to Eric Shea for rebuilding. They come back looking like this:
He's quick and not terribly expensive.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-29-2010, 08:53 AM
djpateman's Avatar
What you are holding is an "A" caliper; it has the 3.5" mount spacing.
The A and S differ in the thickness of the brake pads as far as fitment goes.
There is also the 'wide A" that fits the 24mm rotors as opposed to the 20mm rotors.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 07-30-2010, 10:12 AM
SirAndy's Avatar
I second that!
PMB Performance: Online Parts Catalog (801) 674-3669
Eric does outstanding work ...
Andy
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 07-30-2010, 11:17 AM
PMB Performance
Eric_Shea's Avatar
Wide A-Caliper to be precise. That's a Carrera caliper... all 9lbs. 6oz. of it.
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 08-05-2010, 09:53 AM
PMB Performance
Eric_Shea's Avatar
Make sure you're specific about "Wide" A-Caliper (1984 +), otherwise the el cheapo rebuild houses will send you calipers with 7mm spacers and you'll never get them over your 18lb rotors.
855-STOP-101
Old 08-05-2010, 09:55 AM
