914 headlight problem
Hello, I just purschased 76-914 and last night found out no lights,motors work fine, I check fuse,check wiring at plug in and no voltage any ideas what it could be,Thanks for help?
Old 10-03-2010, 03:55 PM
lights
Check the headlight relay under the main fuse pannel...it should be the square metal one...others are round/black.
Old 10-04-2010, 10:44 PM
Pete000's Avatar
If it is the silver metal relay that is clipped to the metal fuse chassis I have had a contact issue there. Seems the relay needs a good ground to work properly. Mine had a home made jumper wire going to the body to ground it. When I removed it my high beams would not work. Haven't resolved it just yet.
Work to Live, don't live to work...
Old 10-05-2010, 09:44 AM
