911t Fanatic's Avatar
optima red top Batt. question
Will a optima red topbattery, off the shelf, fit in a 1970 914?
Old 04-01-2011, 07:52 AM
rfoulds's Avatar
I went with the smaller 75/25. Fit perfectly.
Randy Foulds, La Quinta, CA
Old 04-01-2011, 09:03 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
The ones that I have experience with are too small for the 914 battery tray. I have used various different solutions to fasten them in. None so far are that good; I will eventually hit on a good home-brew solution.
--DD
Old 04-01-2011, 09:59 AM
optima question
What do you mean by 75/25?
Old 04-01-2011, 01:45 PM
Control Group
Tobra's Avatar
I got one that came with a bunch of adaptors that bolts it in pretty securely, can't recall the number. A 34R, which is the battery my integra uses, is the mini size battery that people use.
Old 04-02-2011, 04:01 PM
Anyone else have a part number for an optima that will fit in my teener?
Old 04-03-2011, 04:20 PM
i've had a red top in mine for about 8 yrs or so now. the stock clamp didn't work, i needed the special optima clamp. the strap is just for extra measure.
doug waters
70 914-6
dougwatersfotos.com
http://www.flickr.com/photos/dougwatersfotos/
Old 04-03-2011, 05:45 PM
redtop
doug waters
70 914-6
dougwatersfotos.com
Old 04-03-2011, 05:49 PM
rfoulds's Avatar
75/25 refers to the model number. It has both top posts and the side screw in GM style terminals. Any Optima that ends in R is a reverse setup, meaning th epositive and negative terminals are switched. For instance, the Boxster takes a 34R, since the Positive cable won't reach the terminal in a normal 34 configuration.
Optimas are generally smaller than stock batteries, and you should use a seperate clamp or strap. The 75/25 comes with a small adaptor plate that you can use under the batttery to lift it to just the right height for the stock 914 clamp and tray.
Search Optima 75/25 at Costco. its usually in stock.
Old 04-04-2011, 10:26 AM
Thanks doug! im gonna get one!
Old 04-04-2011, 12:31 PM
SirAndy's Avatar
--DD
Optima has a adapter for mounting them into the 914. You can get the adapter for free with the battery if you ask for it ...
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 04-04-2011, 02:49 PM
adapter....
i think it says "group 78 adapter", it was free ....
doug waters
70 914-6
dougwatersfotos.com
Old 04-04-2011, 03:16 PM
ill call optima again and ask them, thanks again doug
Old 04-04-2011, 05:37 PM
Yep, Optima is a general configuration battery with all sorts of adapters to fit most different series of batteries out there.
I have two red tops in my 2000 Ford Super Duty. and the right brackets came in the box.
If I were doing tech on the battery with the strap and clip I would fail it for autocross.
My preference for 914 battery is the odessy PC680 laying on it's side with a metal fabbed up bracket to secure in the factory 914 battery tray. Sorry got no picks as I sold the car.
Old 04-05-2011, 06:26 AM
Hi Folks,
I purchased a 34R optima and there are lips on the bottom of the battery that are sticking out over the ends of the tray, meaning it won't sit level. Can I clamp it in like that, or do I need to get a different battery or tray adapter? I called the folks at Optima and they said they did not have a direct fit option for a '73 914 like mine. Thanks!
Old 03-21-2014, 08:23 AM
Control Group
Tobra's Avatar
I seem to remember having to use my dremel to trim the little feet off for it to fit. You can sort of see in these pics. I took pictures when I did it, but those are on the office computer.
Old 03-21-2014, 06:12 PM
