Hand throttle problems in 914-6
Replaced my stock 914-6 shifter with Rennshifter from JWest Engineering. It works great, but now I can not get my hand throttle reattached. Not sure how it gets mouted at the shifter base yes I do have the slot for the hand throttle cut in the base, and also not sure how the long rod gets reconneted to the throttle cable up front.
Any help would be appreciated.
Old 07-02-2011, 04:52 AM
The rod does not connet to the cable. It is supported by a bracket, with bushing, near the front of the tunnel and pushes on a tab that projects fron the side of the accleratoer cable "bracket". Might check the bushing and the tip on the rod as they deterioate over time and may allow for misalignment of the rod.
John
Old 07-02-2011, 08:03 AM
