Hey...
Trying to finally get my oil temp. sump plate to stop leaking. First attempt to do this with a new o-ring going in dry failed....leaks alot! I bought a new o-ring. Now the question is whether or not to use any RTV to make a better seal? Would appreciate any tips! Thanks! Mike
VOPO '74 2.0 |
IMHO don't use RTV unless you have too. Too much chance that a piece might come off and block up something important. Try it without the RTV. Make sure you don't overtighten the bolt!!! If your is not torqueing down it could be that you case has the "syndrome". Good luck!!!!
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
I do not recommend RTV. Dow makes a clear Silicon Paste. Much better (though expensive)
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
914 Geek
"The syndrome" deals with the center sump plate, where the oil pickup is. This is the left-front one, where the oil temp sender is.
There is a paper gasket that goes between the cover plate and the temp sender plate. A new O-ring with clean sealing surfaces (and then a little engine oil), and new crush washers for the bolts. That's what I used; no problems so far. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Thanks everyone!
Dave....was wondering on that one as well, since I too thought the "syndrome" was the center - strainer - plate. I assume we are talking about over-torquing as the syndrome? Now back to the temp sender plate....I don't recall ever having seen the paper gasket as being available. I know that when I replaced the o-ring the first time, I didn't replace the paper gasket as it had fallen apart. So, that could be it... Does Pelican have these ? Thanks, Mike
VOPO '74 2.0 |
Sorry...all I saw was "sump plate" and I made an assumption...you know what happens when people assume...
Use loctite 518 gasket eliminator on that puppy and make sure you use new copper crush gaskets around those 6mm small bolts.
make 100% sure that all oil is off of the parts, no sealer works with oil contaminated parts. The syndrome is a term I came up with referring to the center sump bolt that has been over tightened, resulting in a broken web in the case, this does not pertain to the plate in question in your case.
Jake Raby Raby's Aircooled Technology http://www.aircooledtechnology.com |
Thanks, Jake.
But do I need the paper gasket or just forget about it? Mike
VOPO '74 2.0 |
I toss the paper gasket and use 518 between the 2 plates also. this can be a source for a leak, by it's self. do not put 518 on threads, it is thread locker as well!
What about good old Permetex 3H? It seems like this stuff is good everywhere
![]() Kerry
Kerry (Back on the road, sort of) 914-6 in the Werks |
3H is my least favorite sealer..The 518 is good for most anything where you want zero leakege possibilities. Otherwise I like curil T, K2 and Hylomar.
Jake, I thought in the bug me video you used Permatex just about everywhere? It seemed like you were big fan of that stuff.
When we did the video, I was in the mddle of testing a couple of new sealants. Since then I have pretty much stopped using permatex aviation, it is easy to use, thats why I was such an advocate of it in the video, for the pure novice.
I like the German sealants because they never totally dry, and are easy to clean up if you gotta take it back apart.
