r_towle's Avatar
Question Side shifter mounting question
I need help.
I have changed over the transmission to a side shifter.
The engine mounting bar is the question.
1) Is there rubber where the mount meets the frame of the car?
2) Is there rubber where the mount meets the engine?
I could really use a diagram to make sure I have all the parts..
I got the following
Engine bar with end bolts and rectangular metal plates.
Shifter
Front Shift Rod
Rear Shift Rod
Rear U-joint
Thats all...
Not sure about the engine to bar and bar to car mounts...
Rich
72 914
A Pure bread Pelican machine.
Old 03-21-2002, 05:15 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
You need a Sideshift cross bar (it has a large hole for the shiftrod to pass though), Two motor mounts that attach to the center of the crossbar, Two monting plates that take the place of the T-S motor mounts.Gear shifter assembly to hook up to the front rod, A Conversion Bushing for the shift tube, Rear dust cover. steve
Old 03-21-2002, 06:28 PM
r_towle's Avatar
I have all that stuff.
The engine mounts (bar to engine) can I use the ones from the TS or are they different?
The bar to body mount...Is it just the rectangular plate???
Rich
Old 03-21-2002, 06:34 PM
Banned
they are different , It a c-saped peice you could Fab it up if you dont have one. Steve
Old 03-21-2002, 06:55 PM
gruntie's Avatar
This will help:
Old 03-22-2002, 01:49 AM
r_towle's Avatar
Gruntie...
Thanx a boatload... That is exactly what I needed, but could not find...
Rich
Old 03-22-2002, 09:47 AM
Rich,
For the side-shift mount (top pic) part #2 is the only rubber. The outside mount is bar(#9)-to-plate(#11)-to-frame, no rubber.
Tim
timw700@hotmail.com
Old 03-22-2002, 10:07 AM
I am doing the same conversion. If I want to make the motor mount bracket (Item 1 on the diagram) does anyone know what the dimension from the center of the hole down to the motor mount is? Is it the same as the TS bracket dimension?
Old 03-24-2002, 07:26 PM
Send a message via AIM to JP Noonan
There are so many brackets out there I wouuldn't make one. I had a late 72 parts car with the tail shifter but the part you descibe was the same qas the later side shifters. Can't be 100% but I'm pretty sure the 78 bus engine I took apart also had the later sylte brackets.
93 Lightning
76 912e
Old 03-24-2002, 08:12 PM
Anyone have any late style motor mount brackets for sale?
Old 03-25-2002, 06:25 AM
