ddustan's Avatar
Question Question About Dwell Meter Use
I have been coddled with electronic ignition for many years so have a question about using my old dwell meter.... Other than the obvious two battery leads, where does the coil lead go?
David Dustan
Old 04-16-2002, 06:06 AM
HMeeder's Avatar
Porsche Crest
Uh... not quite clear here.
By 'coil lead' do you mean a clip that looks like it would slip over a spark plug wire?
Most multimeters do several things besides measure the dwell and that 3rd lead slips over the #1 plug wire.
The red lead attaches to the negative post on the coil (it is labeled with a "1" and the condensor wire from the dizzy runs to it.)
The black lead is grounded anywhere you want on the frame/motor.
Herb
'72 Tangerine 'Teen
2.4 liter aluminum handgrenade
Old 04-16-2002, 09:06 AM
ddustan's Avatar
Hmmm... I guess technology has changed in the last 25 years since I bought this thing! This has two battery cables and a yellow lead with an alligator clip. Maybe what I really need to do is go get a new meter. I think its time!
The negative post is what I need I think. Like I say, it's been a long time!!
David Dustan
Old 04-17-2002, 05:36 AM
DSPTurtle's Avatar
Negative post on the coil is what I use...
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 04-17-2002, 06:53 AM
