1.7 Fuel Injection Question
I am trying to piece back together a 1.7 FI system. Is there anyway that I can tell what year the FI system that I have is from? Maybe someone knows of some changes between the years?
It appears that the air cleaner housing is different than one that I saw on ebay listed for a '72 1.7 FI system. This making me believe I had a '73. But in the Haynes Manual, it shows on p. 47 that in '73 the system came with a "supplemental throttle return spring", which my system doesn't have.
Car year isn't going to help as it is a '74, so it isn't the original engine.
One reason for knowledge is that I need another air cleaner as mine is damaged. Maybe this is a lost cause and will have to go to carbs or MAYBE it isn't even a 914 engine? HELP!
NUMBERS:
car-4742915413
engine-EA070223
Thanks,
Old 05-05-2002, 11:20 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
The engine code is a 73 1.7. Is the air cleaner have a paper filter or the oil bath one.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 05-05-2002, 12:01 PM
Ron Meier's Avatar
If you are looking at page 47 of the Haynes Manual, you are looking at the throttle body for a 2.0. It is mounted vertically on the air plenum(air distribution).
The 1.7 is mounted horizontally to the air plenum.
Adding a soft throttle return spring to your car is not that bad of an idea. It just insures a closed throttle in case of cable breakage. Hook it to the cable clamp mechanism and another solid mounting point
"Inventor - Blue Flame 914 Seat Heater"
"Yellow Rusty Cars Are Faster"
_____________________________
'70 2.5 (I'll never finish it - Somewhere over the rainbow.....,)
'73 2.0 (Just Not The Same)
'74 2.0 (Heartless & Lungless)
Old 05-05-2002, 07:21 PM
Geoff, It has a paper filter, and thanks for the year of engine!
Ron, thanks for the clarification regarding the photo in the Haynes Manual.
Feeling much better but have another QUESTION:
Regarding the air plenum, are there supposed to be a couple of hoses that are plugged? What I am referring to are a couple of hoses that are approx. 4 inches and then sealed making their existance useless. Sealed by placing a nut inside the hose and tightened w/clamp.
Thanks,
Old 05-06-2002, 12:20 AM
Ron Meier's Avatar
There are no hoses that should be "blocked off". I'll try to get a hose diagram for a '73 1.7 and post it here (or a photo), unless someone beats me to it. They could be the deaccel valve or aux air valve if memory serves me correct. In AZ, cold start is not much of a problem for most of the year (unless you live near Flag,Heber, etc).
The paper element air filter is also a dead give away for a '73 style engine.
Old 05-06-2002, 05:48 AM
Send a message via AIM to JP Noonan
http://www.pelicanparts.com/914/technical_specs/914_17FI_diag.htm
I think the haynes manual has a better one but this one works.
93 Lightning
76 912e
Old 05-06-2002, 02:33 PM
