Hi all - new to this forum, first post and I don't want to beat a dead horse here but...I plan on towing my 1976 914 from NJ to Denver later this month and I've read a bunch of posts on this topic over the past couple of weeks. Frankly, I just seem to get more confused. Tow bar vs. dolly, facing forward vs. facing backwards, disconnect drive shafts vs. do not disconnect driveshafts. I am planning on...again, going by the general consensus I've been able to glean... using a U-Haul dolly with the front wheels of the car on the dolly and the shifter in neutral. Beyond that I've seen posts advising me to disconnect the drive shafts/axle shafts, disconnect the speedometer, tie the shifter so it stays in neutral, make sure shocks/springs in rear are in top-notch condition, etc. Can anyone who has actually used a U-Haul dolly tell me definitively what is the best procedure? Sorry for the trouble but much appreciate any/all responses. Cheers!
Backwards. Period. End of story. No Porsche should be flat towed.
914 Geek
I know a number of 914s that have been successfully flat-towed various distances, including across the country. Forwards.
I also know of at least two 914s that were being towed backwards and wound up with the windshield blowing out of the car. I think the OP should be fine, as long as they remember to take the car out of gear and disengage the parking brake. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Control Group
Oil in the transaxle is splashing around in there when you are driving, not like there is a pump or anything. I never did get why it would be a problem with the car in neutral
She was the kindest person I ever met |
That distance I'd probably remove the half shafts just to save the wear on the CV's and such. Not a terrible job. The downside is if you need to back it up under it's own power.
Figure out your lights too. I tapped into the stop and turn lights in the 914 and connect to my trailer flat 4 plug. 914 rubber has a nice tow bar adapter. I use that with an Empi tow bar. Works fine. Take it easy and don't try to back it up while hitched. I've also used a uhaul tow dolly. That works fine too.
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
Tabwb, if you disconnect the half shafts....you have to pull them out, can't have them flopping around at speed. Second, if you pull them out you will need an extra set of stub axles to hold wheel and bearing in place. I would pull backwards with windows up, front wheels will lock for good tracking. Best, Mark
1974, 914-6 GT Tribute 2007 Cayman S 1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten. 2017 Golf Sportwagon 4motion Exclusive source for the 914 Umbrella and Service cover |
I cannot get my ‘73 or ‘75 to work with UHaul’s dollys. They are just too high... car bottoms out. I had to use the flatbeds.
Sent from my iPad using Tapatalk Pro |
Trailer is safer/easier than a Tow dolly or tow bar these days. Might depend on the availablity of a tow vehicle though. My dad used to flat tow hi 914 when new in the 1970s cause, well, trailers were rare and expensive and people would tow with "midsize" sedans vs F550s
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
Just spent the money and rent a U-Haul Trailer. Then you don’t have to worry about anything. Also as stated before NEVER TOW A 914 BACKWARDS !!
The 9 Store
I did buy a 914 tow bar adaptor so if my 914 breaks down while I'm sorting it out after a six conversion, I can call my wife and get a quick tow. I would use it for a longer trip if a trailer was unavailable but you have to remember, you can't back up with one.
All used parts sold as is. |
If you have the resources & pull vehicle Id trailer as well but flat towing is safe & economical
No need to pull CV's https://914werke.com/shop/ols/products/flat-tow-bracket |
Your attempt at juvenile humor only reflects your daftness, Mr 50 posts. Anyone with an ounce of gray matter knows backwards towing means on a dolly, to relieve the movement and unnecessary wear of the powertrain. A short trip flat towing is one thing, but a 1000 mile trip is something else, especially when driving at highway speeds.
Clearly you represent a younger generation that is quick to ridicule, especially when you retain anonymity and protection from a social media platform. Punk!
Tony G 2000 Boxster S |
