Where exactly is the Oil Temp. Sensor located?
Hello,
I know this must seem like a silly question but. Where exactly is or does the oil temperature sensor go exactly and is there a wire close by to hook it up on my 75 914 1.8? I just got done installing a center console and It has the wire for the sensor on the harness between the seats. This wire goes somewhere. I lifted the car and look under it, I looked in the engine compartment, and now I have no idea where the sensor is or should go exactly. I kinda figure there is not one on it yet, so I ordered one. When i get it I really need to know where to put it. The haynes manual is not helpful at all. Thanks in adavnce for any help,
Christopher A. Landt 1979 911sc 1973 914 2.0 |
It's behind a round plate with two bolts on the bottom of the engine. Not all engines have them. Search using keyword *taco plate*
Okay, I see that plate. Your saying that if I take the bolts off Oil will not go spalshing out? And that inside will be a place to put the sender unit and there will be a wire there ready to attachto it? That would be easy!
There is also another plate with one bolt that I know has the oil strainer. Thanks, Christopher...
I didn't say oil won't come out. Of course it will if the sender is in oil. And yes, a solid clue as to whether you have a sender is a wire coming out of the taco plate.
Cool! Okay this is all becoming clear. My car has nothing coming out of that area, So I guess I need more that just the sender unit.
Does anyone know where you can get these other parts. The 914 catalog at PP does not seem to list anything like this. Or at least I cannot find anything. Thanks,
PP lists an oil temp sending unit under 914 gauges. I can't remember what mine looks like, it's in a box somewhere as the motor is far from complete. I'd call them. You could also call Greg at FAT Performance in Orange, CA. Or Ron Miener might stop by here and tell us both whats up.
Author of "101 Projects"
There's a little sump plate on the bottom that the sensor fits into. Some of the early engines didn't have a hole there for the sender. You need the sump plate and the sensor if you're didn't have it before...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I have a '75 1.8 with factory console/temp. guage. Had to replace seals at sender because of bad oil leak. Fixed leak, now guage doesn't work so I'm going to go in again with a new sender.
You need (before you start) 1) O ring seal 2) paper gasket 3) two copper sealing rings for the bolts, along with the proper plates (2) for the sender. If you're a purist you also need the rubber boot that seals the wire to the guage. Pelican has all (maybe not the rubber boot) and P. dealer has that as of a month ago. The wire appears in front of the head on drivers side coming from somewhere above. You may have to install one if you can't find yours. I can only see about 6 inches of mine. |
914 Geek
For some reason, this subject comes up every once in a while... I've saved one of my e-mail responses, and am including it below.
- - - - - - - - - - - - - - - - - - - - - Quote:
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
