Zeke's Avatar
Snubbers and lowering front end
I haven't set my front ride height yet as I haven't set the car on the ground to see what the new rear springs are going to do. But, it will be lower. When planning on running a lowered suspension do you need all of the snubber to protect the shock from bottoming out? Can you cut the snubber down by say, half?
Old 06-05-2002, 09:11 PM
Milt, Check the third question on the attached site. It might help with your question. http://www.tech-session.com/Paragon/Info/ask_dr_koni.htm
Mike
Old 06-06-2002, 08:27 AM
Zeke's Avatar
Thanks. When he says cut it down a bit, I wonder if he is cutting one knob off. I might do that for a start.
Old 06-06-2002, 04:30 PM
