canna change law physics
red-beard's Avatar
Question Greasing Throwout bearing
Is it possible to re-pack the throw-out bearing?
James
James
Red-beard for President, 2020
Old 06-18-2002, 07:09 AM
914 Geek
If I recall correctly, it is not--not officially. I remember reading somewhere (packaging for the bearing????) that it was permanently greased and should not be re-packed, that it should be replaced instead.
--DD
Old 06-18-2002, 08:13 AM
I was able to repack mine even though I new better. It seemed dry and in need of grease so I gave it some .It worked fine and saved me $65.It is only about a 3 hour job to change it if it doesnt work.
Doug
Old 06-18-2002, 10:11 AM
red-beard's Avatar
What grease/lubrication did you use?
James
James
Old 06-18-2002, 10:40 AM
I used wheel bearing grease. It should be ok if It wasnt noisy to begin with.
Old 06-18-2002, 10:45 AM
red-beard's Avatar
The tranny has an enourmous amount of grease/sludge inside and out, so I used solvents to clean everything, including the bearing. I just wanted to put some back in.
James
James
Old 06-18-2002, 11:20 AM
Wish I'd heard this two weeks ago when I was cleaning and organizing parts and threw out an old, dry T/O bearing! When you are keeping your cars going through the use of "recycled" parts, every little bit helps.
Old 06-18-2002, 12:34 PM
