canna change law physics
red-beard's Avatar
Rebuild Article
K - here's the tranny article, until I put the additional pictures in....
James
http://home.san.rr.com/pb914/rebuild/
Whoa! I have a home page.
James
Red-beard for President, 2020
Old 07-10-2002, 10:09 PM
Red-beard, fantastic job you did there on the "tranny rebuild" site! VERY detailed!
"Whether you think you can, or think you can't, you're probably right" - Henry Ford
'73 914
'75 914
Old 07-11-2002, 07:56 AM
red-beard's Avatar
And I'm not done yet....I need to edit it a bit more and I need to add many more pictures. And the final pictures will be a little higher quality....
James
James
Old 07-11-2002, 08:14 AM
Red-beard,
VERY NICE.... VERY IMPRESSIVE....
brant
Old 07-11-2002, 08:22 AM
KenH
Guest
Posts: n/a
Just a couple of comments.
1. Dont forget to mention the gasket thickness between the transmission case and the Intermediate plate - setting the "R" value.
2. Torque values for the Pinon and Mainshaft nuts.
3. Discribe the shifter-shafts lockout system - maybe a diagram showing how they fit.
Ken
Old 07-11-2002, 08:39 AM
red-beard's Avatar
Yep, this is what "editor's" are for.
Definitely need to include the thickness (by color) and the torque values. Although, trying to truly set the torque value for the main shaft nut is almost impossible. I torque it down until it's in the same position. I reuse the locking washer, but I remove the used side and bend a new side. I flatten and file the snapped side.
I'm trying not have people remove the shift rods, so I didn't go into lockout system. You can remove the gear shafts without removing the sliders (Except 1st gear). This is one less step. Not a bad idea though. Re-assembling the balls and springs is a PIA.
James
James
Old 07-11-2002, 09:03 AM
red-beard's Avatar
I changed a few of the graphics so the page will load a little faster.....Still kinda slow at modem speeds...
Sorry, my bad!
I also updated quite a bit of the text. Even ran the speel checker on it. This weekend, I'll be shooting a bunch of pictures: taking the gear stacks apart, some pictures comparing dogteeth, etc.
On the top level, you can download a PDF version. It's about 1.9 MB
One note: The pictures are actually larger and better quality. You can save them individually and they are much clearer. In the final version, I'll thumbnail them.
Keep the comments/critques/suggestions coming!
James
James
Old 07-11-2002, 02:53 PM
