Question such thing as 14" fuch rims?
is there such a thing as 14" fuchs???? is that the typical size to use on a 914?....or are 15" better?......thanks...john c.
john c.
Old 07-18-2002, 06:57 AM
rdvnac's Avatar
The 914-6 came with 14" 5-lug Fuchs rims identical in appearance to the 15" 911 rims of the era.
Unless you have a sixer and are a stickler for authenticity, 15" Fuchs (whether 4-bolt "2-litre" style as on the 4-cylinder cars, or 5-bolt 911 style, like my avatar to the left) would be a better choice.
Bob D.
rennlist
PCA Chicago Region
1970 914-6 (sold)
1998 993 C2 S (sold)
Next Porsche?
Old 07-18-2002, 07:21 AM
just curious....but what is the difference between a 15" and a 14" rim????why would someone prefer a 15" rim???..
john c.
Old 07-18-2002, 09:47 AM
rdvnac's Avatar
More wheel + less rubber within the overall diameter of the wheel/tire, plus lower profile tires, means crisper handling.
And, in this era where even mom's Camry has 16" or 17" wheels, it's hard enough finding a variety of tire choices in 15" tires. 14" tires are getting to be the 8-track tape of the tire world.
Bob D.
rennlist
PCA Chicago Region
1970 914-6 (sold)
Next Porsche?
Old 07-18-2002, 09:54 AM
914 Geek
My own question is, "Why would anyone prefer a 14" rim?"
The selection of tires is much bigger in 15s, and in the five-bolt wheels you can get much wider 15s than 14s.
Originality is about the only real reason I can think of.
Rust-boy from the Rennlist was recently looking for performance-oriented tires for the 14s on his Six. Selection was very limited indeed...
--DD
Old 07-18-2002, 11:05 AM
here is the thing...i want to use 15" fuchs...but i dont want to adjust or cut the fenders.....will the 6x15" fit without modifications?????
john c.
Old 07-18-2002, 12:05 PM
forgot one thing....i dont have a 911 bolt pattern and i dont want to use an adapter..so i plan on drilling....does this sound typical.....1974 914 2.0...
john c.
Old 07-18-2002, 12:06 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
I just put 6x15 5 bolt Fuchs on my 76 2.0l with 205x 50's tires. No problems! I had the rear hubs drilled and new front disc's drilled and the hubcentric part machined off so I could use the 911 Fuchs. Worked great! These were early windmills so the offset is right.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 07-18-2002, 01:50 PM
914 Geek
I would not recommend drilling and using lug bolts. I think that drilling and using press-in studs is a good way to go, but I think that bolts are somewhat iffy.
Remember that the front hubs and front rotors are the same thing on four-cylinder 914s. That means drilling again every time you have to replace the rotors. (Hint: Buy new rotors for this!)
For more info on the five-lug conversion, see the tech article of the same name elsewhere on our site!
--DD
Old 07-18-2002, 02:09 PM
Bleyseng's Avatar
I think its a nobrainer to use the press in studs on the conversion to 5 bolt. Besides with the bolts its tough to hold the wheel and line up the holes and then screw the bolt in! With studs (German one of course) you just pop the wheel on and screw the nuts on.
On the rear hubs, I did use the later style hubs but after I had the studs pressed in, I tack welded each stud so it couldn't come loose or spin on me. Once the rears are bolted together there is plenty of meat to hold everything together vs using the early style hubs.
Have fun installing the new rear bearings...god what a job that is!
Geoff
www.914Club.com
My Gallery Page
Old 07-18-2002, 04:38 PM
canna change law physics
red-beard's Avatar
Khumo makes a 195 60 14
4000 RPM at 80 MPH. Oh my ears....
The right fitment would be 195 75 14
I have 15's...but the 14's are on the car while I'm painting. Damn the 14's look nice though. So much work, on just 14's. I wish I knew who the previous-previous owner was. I'm just afraid it was George Hussey....
http://home.san.rr.com/pb914/gallery/fuchs6.html
The 15's are getting my 205 60 15 Yokohama AVS dBs. Very sweet tires.
James
Red-beard for President, 2020
Old 07-18-2002, 08:56 PM
14" Fuchs?
FWIW, the '69 911 T was available with 14 x 5 1/2 Fuchs. I'm not sure about 911 E's or '70-71s, though. I have seen a few T's running them. I thought (just a guess) that maybe it might have been a less expensive alloy wheel option (15" steels were standard for the 914-6 and 911) back then, compared to the 15 x 6s. Back then, not too many cars were running 15s. Caddys, Lincolns, Riveras, station wagons, Monte Carlos, Electra 225, usually big, heavy cars with VW and Porsche as the only small cars that I can think of.... 15s came standard on Vettes, but were an option on some GM muscle cars. Ferrari was still running 14 " Mich XWXs. As far as road handling cars/tires, there was Porsche and Corvette, so there was a larger tire selection back then for 14s. Type II VW (bus/pickup) had 14s because of the tire size/selection that could carry the heavier loads. I think that the Mich XWX was THE street tire back then, after that maybe the Pirelli CN36. Goodyear had their Polyglas, Firestone had Wide Ovals, domestic tire sizes still had letters. HA! Just my misguided opinion/ramblings. Some of the 356 C/SC guys want the 14x5 1/2s for their cars (or used to).
Old 07-22-2002, 03:57 PM
Senior Member
Hello
The 14" Fuchs where used as comfort option for 911 and 914/6
Grüsse
Old 07-23-2002, 03:59 PM
