Smoke from the muffler...
Just installed a new Bursch muffler on my 2.0, along with new gaskets (of course). At the same time I put new gaskets on the intake manifolds. When I started it up, I got pretty thick white smoke from the right side of the muffler, where the muffler bolts to the exhaust headers. It doesn't smell at all like oil, but almost like something burning (like plastic). Any ideas?
Joe '74 2.0 |
paint, the collecter area will lighten up too. joe keeping your car out of the rain?
I was hoping it was something like that. It kinda smelled like paint, but I couldn't figure out why there would be paint burning off. Thanks.
And no, my poor Porsche is out in the rain all the time. The up side is that I never have to wonder if the seals are good; I know pretty much immediately when they're leaking. Thanks again Joe '74 2.0 |
Chaps my ass to see a new muffler setup burn its crappy paint off and rust within 10 days of owning it.
How many people would buy a SSI 914 2.0 muffler ?? Raise your hand. B |
See one hand raised - as long as the price is not crazy. In line with similar 911 SS muffler would be appropriate.
Me too
I would love it if those guys at BORLA would make some more of those units for our little cars. All port matched and ready to run maybe dual outlets.
Could go a little louder my nieghbor over slept the other day waiting for my 928 to roll out of the garage. the Bursch on my 914 just is too quiet
914 Geek
B, depends on the specifics of the muffler. We already sell a stock-equivalent (or near-equivalent) in SS, but it aint cheap.... Something like a Bursch (merged four-two-one or four-into-one) would have some demand, but if its priced above about $400 youll have problems getting folks like the CSOBOSC to buy it. And probably others as well.
Some design work with dyno charts to show power increases on stock motors ought to help sales some, but price is gonna be a really major factor. We are 914 owners, after all... ![]() --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
$400 beans for the equivilant of another bursch? thanks anyway but i'll pass. i'm counting my penny's for a triad unit. if you can believe dyno curves (not just theirs, anyones) it seems to be the real deal, nice exh note too. there are other units that are said to produce power but the eliminate the heat exhs. it's not just heat, i have to have defrosters too. my heating system in the cursed 72', ss exch good and sealed up tin would warp vinyl records. and i believe it's less exspensive, the triad that is.
kevin |
When I removed my Bursch after several years of use I was surprised by the paint that remained on the muffler and tail pipe. The four primaries up to the muffler, the part you see from the rear of the car, all had the classic Bursch rust finish. Structurally the unit was still solid though. My new Mittlemotor SS looks better!
Mike |
You might want to try POR-15 hi temp manifold grey. I used some on both our stock 914 muffler and it lasted over 2 years and also on the race car muffler which has lasted about 3 years.
I've tried a muffler paint on my stock 2.0 muff and got BIG flaking. How did you apply the POR-15 and where di you get it? Who makes it?
914 Geek
Hunh! Sorry, I must be mis-remembering on the SS version of the OE muffler!
I thought I remembered that from the catalog, but it isn't there now...POR-15 has their own website. I think it's http://www.por15.com . --DD
As Dave noted, POR-15 paints are available from their website by mail. I follow their instructions exactly for which ever product I am using and I think it was remove all loose rust/paint, bruch to remove rust then appply a smooth even coat. After it is dry to the touch you have to bake it usually by running the engine and letting it cool but I don't rememberfor how long? I think there are a few others here that can verify that POR-15 products are pretty good. Good luck.
Ditto on the POR-15 Hi Temp Manifold gray...
Worked well for me and was a lot cheaper than new parts... SS or not... - Dave... member CSOBOSC |
I used POR-15 on my bursch muffler (grey rust converter covered with their glossy black). It looked real nice but it too started smoking as soon as I started it up....It eventually peeled off but I think that the grey rust converter is still on. The POR-15 does not come off the muffler though (this runs cooler).
I used POR-15 high temp paint and it still came off. It is only rated for around 600deg. (But like most high temp paints, i think you need to bake it on to get this protection) I still recommend it though as it stays on the muffler (it also looks great on engine tin). Justin 74 914 1.8 |
Not a Bursch replacement. A brand new all Stainless Steel replacement banana muffler like the stock one with a different note and a little more flow.
News Flash: The Dansk mufflers are steel inside and SS on the outside. They rust from the inside out. The plan is to offer a new muffler in the 300$ price range retail. The early 911's and 914's used the same muffler with different inlets. B |
Sounds good to me...
Fixtures and dies are done. Flanges and baffles are currently be revamped.
The quality will rival everything else you have seen from a certain manufacturing company. Look for Pelican to offer it before anybody else. I would like highly detailed photo's of Mittelmotor muffler. Specifically the build quality and finish. B |
