Curvie Roadlover's Avatar
Dumb Question
Allright, I have a '76 2.0 and I can't find the fuel filter. I believe it to be up front but I don't see it. To be honest I haven't looked from under the car but I thought I was supposed to be able to access it from the front trunk. You don't have to pull out the tank to change the filter do you?
Malaga Red '76
Old 08-09-2002, 08:08 PM
dave blackburn's Avatar
If it is the same as my 75, the fuel filter is behind the fuel pump ( or close to it) in the front trunk. There is a bulge in the carpet on the drivers side of the trunk wall, take off this pannel and you can see you fuel pump and hopefully your filter. Hope this helps, Dave
Old 08-09-2002, 08:37 PM
OK, so I took the panel off and there was the fuel pump. Sitting behind it was the filter. There is no way to get at the filter that I can see without removing the pump. And even then it looks like access to the filter is questionable. Looking through that access panel and imagining how I would ever get at the filter reminds me of those ship models in a bottle people somehow build. It looks like removing the whole tank to get at the filter would be easier than trying to work through the access panel. Is there a better way?
Malaga Red '76
Old 08-10-2002, 04:54 PM
Jim Smolka's Avatar
Lightbulb
To replace the filter, it might be easier to lift the gas tank out. Since the lines are probably original, it is a good idea to buy HP FI lines from Pelican and replace the old lines. Just be carefull not to kink the new lines when installing the gas tank.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 08-10-2002, 06:20 PM
mejulihn's Avatar
When I replaced my fuel filter, there was enough slack in the fuel lines to remove it from the access hole in the trunk. See if yours can do the same.
Old 08-10-2002, 07:45 PM
Was your fuel pump in the way and did you have to remove it to get at the filter?
Malaga Red '76
Old 08-10-2002, 07:53 PM
