Turboman's Avatar
Send a message via Skype™ to Turboman
914-6 Brake Improvement
My 914-6 needs an overhaul; yes the engine still on its original pistons and barrels, close to 250K miles, burn some oil…………… seems the time has come to open and improve the engine. But before I put the engine down, I plan to improve the brakes.
The front brakes, an easy decision, new struts and aluminum 72/72 S calipers.
The rear, I want a more elaborated solution. I want to use ventilated discs, with the original calipers rebuild and suit to use those discs.
I know I need to split the calipers and fit a spacer. Few years back, my old friend Jim Pasha gave me the part number of the spacer. I lost the reference. I know that is the same spacer of some stock calipers used on 70s Porsche
Does any one of you have the reference? Or the info about the calipers equipped with the needed spacer.
Appreciate all the help.
Francisco
Old 12-06-2013, 03:51 AM
914 Geek
Early M calipers have a spacer that fits nicely. It can be a bit hard to find them, though.
You could simply send your rear brakes to Eric at PMB Performance. I think he makes his own spacers. He is also pretty much the expert on 914 brakes. He can also set you up with the rotors.
I knew Jim as well, when he lived in California.
--DD
Old 12-06-2013, 07:44 AM
The 9 Store
I think the spacers are available but the right size bolt may be an issue. But Dave is right, Eric at PMB is your guy.
Old 12-06-2013, 09:25 PM
ASE Master Tech - 35 yrs
larrym's Avatar
this has been discussed many times on this site - do a search
the quick answer is oem 914-6 rear calipers with spacers and 911E vented rotors - i have that set on my m471 car as built in Germany - can provide a few pics if ya want
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 12-07-2013, 09:06 PM
Turboman's Avatar
Dave, thanks for your advice, I have a problem and that is the distance from my location to the USA, and the customs procedures. Francisco
Old 12-09-2013, 11:40 PM
Turboman's Avatar
Larrym: If you have some photos to share with me, will be fantastic. Thanks Francisco
Old 12-09-2013, 11:41 PM
totle's Avatar
Any source for where to buy the spacers ?
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 12-10-2013, 03:24 AM
914 Geek
Totle, see the link for PMB above.
Turboman, if shipping and customs is too much of a hassle for you to send your calipers off, I bet that Eric would still be willing to send you all the bits you need to do the rebuild and conversion yourself. That at least reduces the shipping hassles to one-way.
He has a good illustrated rebuild procedure for the rear calipers in the "Classic threads" section of the 914world BBS, as well, which should take the surprises out of it for you.
--DD
Old 12-10-2013, 07:41 AM
djpateman's Avatar
The spacers and bolts come from a stock vented 911 rear caliper 1969 into the late 1970's, so not a problem to find. The metal "+" spreader is from the same caliper. The pins though are unique to the GT caliper so contact PMB for those. You will probably need a spacer to use the 911 brake rotor, or you could find the GT rotors as I did. Although I do caliper rebuilds myself, my solution was to send the calipers to Eric at PMB for the conversion and restoration.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 12-23-2013, 06:50 PM
