Location: Central Coast CA, South Eastern WA, Bay Area CA and MAUI Hawaii
6 Foot Driver in a 914
I'm thinking about getting my son a 914 he is 6'1
any tall 914 guys chime in
86 930 turbo perfect
89 911 targa will be someday
95 surburban 180k and still love it
87 300d mercedes airport car
Living Life Is......
Choices and Chances
Make Some and Take Some
Old 06-01-2014, 09:23 AM
I'm 6'3" and bought mine when I was 20 years old. Still have it. No problems.
Old 06-01-2014, 03:05 PM
gearhead
6'3" no problems. In fact more comfortable than my 911
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-01-2014, 03:11 PM
I'm 6' 5". Not enough head room but there's enough leg room.
Currently have: Guards Red 1987 924S 16v -- Light Blue Metallic 1980 928
Gone: Minerva Blue 1979 928 -- Gray 1985.5 944 -- Black 1989 944 -- Black 1984 944 -- Black 1987 944S -- Alaska Blue 1974 914 1.8 -- Guards Red 1983 944 -- Guards Red 1987 924S -- White 1988 924S -- Maraschino Red 1987 944 Turbo -- Beige 1981 924 -- Red 1984 944
Old 06-01-2014, 03:22 PM
Gustl's Avatar
I'm 6'4" and 275 lbs and have no problems
it's a little close between the shift stick and the steering wheel, but not a problem
Old 06-01-2014, 11:23 PM
you only need two feet to drive a stock 914, the four other feet are useless. If you got one foot, consider an automatic transmission car.
Old 06-02-2014, 11:06 AM
914 Geek
I am 6'1", but have a long waist. I have headroom problems in many cars. The 914 is better than most, though a bit marginal for me with the stock seat. My head will brush the headliner when the roof is on the car.
If I remove the bottom seat cushion, or replace it with a thin foam pad, I have no problems. Even with a helmet on.
--DD
Old 06-02-2014, 01:43 PM
thanks guys
may have another car in stable soon
Choices and Chances
Old 06-02-2014, 07:34 PM
I'm 6'6" and 275lbs and my brother is 6'4" 200"lbs and we both fit in the car. We were shocked we both fit when I was test driving the car before I bought it.
The shifting could be tricky where it hits your leg for first gear but you can get a short shift or cut the shifter length down and it is not an issue. Mine was missing a base cushion, which are pretty thick, so when I had mine made I used better foam and had a thinner one made. This can get you an inch or two.
Old 06-05-2014, 08:39 PM
